Dear Colleagues;
I have to convert many text to mtext, so that I can choose background mask But how to do? Is it one by one, If I select all text at a time you know what will happen? Example: Road Chainage
I look forward to hear from you soon as possible
Automohan
Solved by pendean. Go to Solution.
Solved by imadHabash. Go to Solution.
Use this Lisp.
First select all texts using select similar > T2m.
Cheers,
Vinay Vijayakumaran
If their justifications are not all some variety of top-justified, use this routine [Text1MtextJust2.lsp with its T1MJ] command, and the resulting Mtext objects will each retain the justification of its source Text object. See comments at that page and at the top of the file.
If all you are wishing to do is to create a background mask, I advise just using the TextMask command within Express Tools.
This works on regular Text objects, meaning you wouldn't have to convert all the text objects in Mtext.
I've run the command on the DWG you attached so you can see how it looks.
Joe
here is the shortcut
Because you have teouble with TXT2MTXT, or what is the main difference?
Sebastian
@projeto16YZ6W wrote:
I used this lisp in AutoCAD LT just now and it works perfectly! Thanks @Vinayv4v !
Why if I may ask? The command is built-into modern versions of LT including LT2024
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-1E68C8B2-520F-4084-BD20-51DC4A32A7E5
Yeap, I discovered this command in LT later. 🤣 It was only because people talked about this command in Express Tools (that I know that isn't in LT version) that I looked for an alternative. Tks.
