AutoCAD Forum
Convert text to Mtext
11 REPLIES 11
Message 1 of 12
Automohan
37103 Views, 11 Replies
Dear Colleagues;
I have to convert many text to mtext, so that I can choose background mask But how to do? Is it one by one, If I select all text at a time you know what will happen? Example: Road Chainage
I look forward to hear from you soon as possible
Automohan
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
11 REPLIES 11
Message 2 of 12
imadHabash
in reply to: Automohan
from Express tools i suggest to use TXT2MTXT command line .  >> Click <<
Command: TXT2MTXT
Select text objects, or [Options]<Options>:
Select objects:
Imad Habash
Message 3 of 12
Automohan
in reply to: imadHabash
I have attached a dwg
"Save Energy"
Message 4 of 12
Vinayv4v
Use this Lisp.
First select all texts using select similar > T2m.
Cheers,
Vinay Vijayakumaran
Message 5 of 12
Kent1Cooper
If their justifications are not all some variety of top-justified, use this routine [Text1MtextJust2.lsp with its T1MJ] command, and the resulting Mtext objects will each retain the justification of its source Text object.  See comments at that page and at the top of the file.
Kent Cooper, AIA
Message 6 of 12
If all you are wishing to do is to create a background mask, I advise just using the TextMask command within Express Tools.
This works on regular Text objects, meaning you wouldn't have to convert all the text objects in Mtext.
I've run the command on the DWG you attached so you can see how it looks.
Joe
Message 7 of 12
nnmohammed2013
Message 8 of 12
jwilliamsZRQUC
Quickest way now
Message 9 of 12
projeto16YZ6W
in reply to: Vinayv4v
I used this lisp in AutoCAD LT just now and it works perfectly! Thanks @Vinayv4v !
Message 10 of 12
cadffm
in reply to: projeto16YZ6W
Because you have teouble with TXT2MTXT, or what is the main difference?
Sebastian
Message 11 of 12
pendean
Why if I may ask? The command is built-into modern versions of LT including LT2024
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-1E68C8B2-520F-4084-BD20-51DC4A32A7E5
pendean_4-1709224338390.pngpendean_5-1709224355303.pngpendean_6-1709224370858.pngpendean_7-1709224387242.png
Message 12 of 12
projeto16YZ6W
in reply to: cadffm
Yeap, I discovered this command in LT later. 🤣 It was only because people talked about this command in Express Tools (that I know that isn't in LT version) that I looked for an alternative. Tks.
Forma Design Contest
