Convert mm to m
andreiandronache13
Convert mm to m
andreiandronache13
Hello! I have a problem. I would like to change from mm to m and I can't, I tried with the UNITS command and with DIMSTYLE, but it still doesn't work. Can you help me? When I select the LINE command, it shows me 3823.6581. I want it to show me 3.8236881. Please help me, I searched all kinds of tutorials on the internet, but I couldn't do anything... Thank you!
Replies (8)
paullimapa
did you try scaling all the objects in the drawing by 1/1000 = 0.001
Paul Li
IT Specialist
@The Office
Kent1Cooper
What it's showing you is drawing units, which obviously represent millimeters.  If you want the drawing unit to represent a meter, you should scale the whole drawing down by 1/1000.  I suspect that the Dimension Style used to draw those Dimensions has a measurement scale factor of 0.001 applied, so that the numbers come out in meters instead of in mm [drawing units].  If you scale everything down, change that measurement scale factor to 1:
If those Dimensions have that measurement scale factor imposed as a Property override, rather than in the Dimension Style definition, change that to 1 also:
Kent Cooper, AIA
andreiandronache13
I tried but still can't convert.. here is a video
bandicam 2022-12-23 21-37-23-549.mp4
Video Player is loading.
Current Time 0:00
Duration 0:42
Loaded: 23.18%
Stream Type LIVE
Remaining Time 0:42
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    andreiandronache13
    Current Time 0:00
    Duration 0:42
    Loaded: 23.55%
    Stream Type LIVE
    Remaining Time 0:42
    1x
      • Chapters
      (view in My Videos)
      Kent1Cooper
      After Scaling everything down, then change the measurement scale factor in the Dimension Style, and also the "Scale for Dimension features" setting so the parts don't overwhelm:
      If the Text Style assigned to that Dimension Style has a fixed height, you may need to change that, too [either the Style assigned, or its fixed height.
      Kent Cooper, AIA
      paullimapa
      you were doing such a good job scaling everything down. But then you didn't continue as others have instructed you here to change the dimension style so the dimension texts will scale down as well.
      Paul Li
      IT Specialist
      @The Office
      andreiandronache13
      Thank you very much!!!!!!! You helped me a lot!!!
      andreiandronache13
      Type a product name
      ______
      icon-svg-close-thick
      Cookie preferences
      THIRD PARTY SERVICES
      icon-svg-hide-thick
      icon-svg-show-thick
      Qualtrics
      Akamai mPulse
      Digital River
      Dynatrace
      Khoros
      Launch Darkly
      New Relic
      Salesforce Live Agent
      Wistia
      Tealium
      Upsellit
      CJ Affiliates
      Commission Factory
      Typepad Stats
      Geo Targetly
      SpeedCurve
      Qualified
      icon-svg-hide-thick
      icon-svg-show-thick
      Google Optimize
      ClickTale
      OneSignal
      Optimizely
      Amplitude
      Snowplow
      UserVoice
      Clearbit
      YouTube
      icon-svg-hide-thick
      icon-svg-show-thick
      Adobe Analytics
      AdWords
      Marketo
      Doubleclick
      HubSpot
      Twitter
      Facebook
      LinkedIn
      Yahoo! Japan
      Naver
      Quantcast
      Call Tracking
      Wunderkind
      ADC Media
      AgrantSEM
      Bidtellect
      Bing
      G2Crowd
      NMPI Display
      VK
      Adobe Target
      Trendkite
      Hotjar
      6 Sense
      Terminus
      StackAdapt
      The Trade Desk
      RollWorks
      Your experience. Your choice.
