Current Layout to specified page setup current
Philj215
Message 1 of 8
Philj215
We setup multiple page setups on all of our drawings that are the same. One of them is called PDF. I want to set the current layout to "PDF" page setup. Is there a lisp routine that will achieve this to save me some time?
I normally do this process:
type: pagesetup
click PDF from the page setups
click the set current button
Replies (7)
Message 2 of 8
paullimapa
Message 3 of 8
cadffm
@paullimapa wrote:
Explore Ctab variable
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoC...
I would say: Command -PLOT no
and stop the plot at the end of this command.
CTab is good for a layout jump, not to set a pagesetup.
@Philj215
Sure you will find a short tool to set your named pagesetup,
but -PLOT is the way to go if you like to create your own solution.
Sebastian
Message 4 of 8
paullimapa
try using this lisp function to do this but Note: Does not check if given pagesetup name exists or applies to given layout space
; putPagesetup function places an existing pagesetup onto layout
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-for-page-setup/td-p/9386936
; arguments:
; document - (vla-get-activedocument(vlax-get-acad-object))
; layout - (getvar"ctab")
; setup - existing pagesetup name
; Usage:
; (putPagesetup (vla-get-activedocument(vlax-get-acad-object)) (getvar"ctab") "PageSetup Paper") ; given existing pagesetup name: "PageSetup Paper"
; Note: Does not check if given pagesetup name exists or applies to given layout space
; Returns T if successfull or Nil if fails
(defun putPagesetup (document layout setup)
;Jason Piercey
(vl-load-com)
	(if
		(vl-catch-all-error-p  (vl-catch-all-apply
			(function
				(lambda ()
					(vla-copyfrom (vla-item (vla-get-layouts document) layout) (vla-item (vla-get-plotconfigurations document) setup))
	 nil  t
) ; defun
Paul Li
IT Specialist
@The Office
Message 5 of 8
maratovich
Maybe this will help you - Revers
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 6 of 8
paullimapa
I don’t see any feature in your app that addresses the OP
Paul Li
IT Specialist
@The Office
Message 7 of 8
maratovich
@paullimapa  написал (-а):
You will see when you run the program. If you don't run you won't see anything.
Watch at least the video tutorial.
It automatically assigns all required print options to all layouts.
www.kdmsoft.net
Message 8 of 8
paullimapa
I watched the video.  Like I said, your app has nothing to do with OP. Go back and read it carefully.
Paul Li
IT Specialist
@The Office
