Need to extract path from a sweep solid
karl.trolenbergV2BMK
I have a 3d solid that was created with a sweep (shape along a path).
I need to extract the original shape and path from the sweep. I can actually see the path inside the solid and adjust it to some degree, like moving one vertex at a time, but I can't adjust the shape as far as I can tell.
Using explode only leaves me with some of the shapes along the path but the path itself and outer edges are destroyed.
I have attached the model. Any help would be appreciated.
parkr4st
CONVTOSURFACE
eXplode the surfaces leaves the attached.
The kink in the spline upper right end needs fixing?
Thanks for your help!
