Convert an image to CAD format
lkirit2000
Advisor Advisor
Message 1 of 14
lkirit2000
Hi Team,
I have a company Logo and I need to cut it out in sheet metal—the Logo in png or jpeg file.
Is this possible.
Replies (13)
Message 2 of 14
imadHabash
You can attach raster image to DWG with ATTACH or IMAGEATTACH commands. In AutoCAD, the term "trace image" typically refers to the process of using an imported image as a reference to draw over it, creating a new set of vector-based geometry. While there isn't a single "trace image" command that automatically converts a raster image to vector lines, several commands and features ( LINE, PLINE, ARC, CIRCLE, SPLINE ) are used in conjunction to achieve your need.
Imad Habash
Message 3 of 14
j.palmeL29YX
Depending on what the logo actually looks like, AutoCAD Raster Design (if you have access to) may be helpful to recreate the logo in vector data.
Jürgen Palme
Message 4 of 14
autoid374ceb4990
The logo is in PNG or JPG format?  What format do you need for the final product?  Do you need just a line drawing, or a 3D model similar to the attached picture?
Message 5 of 14
VincentSheehan
I have used a few online services in the past with success. PNG or JPG to DXF or SVG.
https://convertio.co
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 6 of 14
lkirit2000
Hi
My logo has text and numbers,
I need to convert to dxf to cut in sheet metal.
Kiri
Message 7 of 14
TheCADnoob
Ive done this type of thing often.
I frequently find it best just to redraw in AutoCAD with the help of the raster tool set.
If the logo is simple enough you may have luck usning conversion tools. I frequently use inkscape to get vertor versions of images, though it depends on several factors as to whether it comes out well. Inkscape is open-source and can output to dxf.
99% of the time though i get better results traing over the image in AutoCAD.
CADnoob
Message 8 of 14
lkirit2000
Hi j.palmel29YX,
My Logo has text and letters.
Please explain the details steps in how to achieve in Raster Design ?
Kiri
Message 9 of 14
autoid374ceb4990
Can you post a picture of the logo?
I agree with TheCADnoob, you will probably get better results by tracing the image.
Message 10 of 14
j.palmeL29YX
Without knowing the logo it is hard to help.
Jürgen Palme
Message 11 of 14
RSomppi
How far have you gotten? Are you stuck on a particular step?
You can find tutorials on how to use the program. If you struggle with certain aspects, you can probably get help here.
Message 12 of 14
lkirit2000
Hi Imad,
Appreciate your guide. I bought the imahe in to the Acad file.
Now, do I need to do it manually, or is there any command will work?
Message 13 of 14
imadHabash
Yes, you have to start manually trace over the image. There is NO other way to get an accurate result.
Imad Habash
Message 14 of 14
DGCSCAD
The size and quality of the image will determine the vector conversion output in any raster to vector app, but in most cases a redraw is the only way to achieve a usable vector reproduction.
Some redraw points to consider:
  • MyFonts.com (used to be WhatTheFont) has a font finder that can help in identifying any fonts used in the image.
  • Importing the image into an AutoCAD drawing, then setting the transparency to about 50% will give you a good starting point for tracing.
  • Set the image to the back using DRAWORDER.
  • For tracing, the use of small incremented plines that can be splined if needed, paying extra attention to any squared off corners, helps to keep things smooth and tidy.
  • For hatching, in order to eliminate any 'bleed through' (thin streaks), or lapse in color in solid hatches, copy the hatch in place, then set the angle of the new hatch 90° perpendicular to the original.
From someone who has been down that road many times.
AutoCad 2018 (full)
Win 11 Pro
