Automate for selecting all circles & delete from entire drawing
sanjayph1111
Message 1 of 16
sanjayph1111
I want to automate for selecting all circles of 5mm dia & delete from entire drawing
Replies (15)
Message 2 of 16
sanjayph1111
Qselect is not working for this even try to record macros...
Message 3 of 16
sanjayph1111
Please if anybody can provide me the solution for this
Message 4 of 16
cadffm
if you drawing is drawn 1unit=1mm, this is a simple statement to erase all 5diam circles on non-locked Layers in the current space only.
Command: (if (setq ss (ssget "_X" (list'(0 . "CIRCLE")'(40 . 2.5)(cons 410 (getvar 'CTAB)))))(command "_.erase" "_p" ""))
Sebastian
Message 5 of 16
sanjayph1111
Great ...
Thanks a lot... Its working perfectly... 🙂
Message 6 of 16
sanjayph1111
Can I make a shortcut key for the same as this is too repeated work... I added ZOMM all also to this one & now if you can provide to make macros for this one, please ...
(command "_.zoom" "_a")(if (setq ss (ssget "_X" (list'(0 . "CIRCLE")'(40 . 3.5)(cons 410 (getvar 'CTAB)))))(command "_.erase" "_p" ""))
Message 7 of 16
cadffm
Hi
we changed from 5.0 to 7.0 ? okay
>" if you can provide to make macros for this one, please ..."
Macro? You can add the line in macros, so what is the problem?
Create a Command-Tool in your Toolpalette or any other Button for Toolbars, menus or Ribbon and add the line.  ^C^C^C(command "_.zoom" "_a");(if (setq ss (ssget "_X" (list'(0 . "CIRCLE")'(40 . 3.5)(cons 410 (getvar 'CTAB)))))(command "_.erase" "_p" ""))
>"Can I make a shortcut key"
Shortcut are defined in you CUI
but I can offer edited lines, so after load a new command is available: DelAll7diaCircles
(defun c:DelAll7diaCircles nil
 (princ)
Sebastian
Message 8 of 16
Kent1Cooper
@sanjayph1111 wrote:
Qselect is not working for this ....
I'm curious about that -- it should work.  Could you be doing something like giving it a radius where you should be giving it a diameter?
Also, suggestions so far work to remove Circles in only the current space, because the Erase command in an AutoLisp (command) function with object selection can "see" only those.  It would not be difficult to write something to remove them from all spaces in the drawing, if you need that.
Kent Cooper, AIA
Message 9 of 16
cadffm
Quote: I want to automate for ...
Sebastian
Message 10 of 16
sanjayph1111
I created shortcut Key also for the same. But the issue is that for some files it works & not all. I checked the dimensions as you can find in attached screenshots...
Message 11 of 16
sanjayph1111
Find DXF File as well
Message 12 of 16
Brock_Olly
Your white circle isn't exactly 7, it's 6.99998600 (set LUPREC variable to 8 and see)
When I edit the property to 7 and run the command it works fine.
Here's Cadffm's command updated to give some tolerance: (0.01)
(command "_.zoom" "_a") (if (setq ss (ssget "_X" (list '(0 . "CIRCLE") (cons 410 (getvar 'CTAB))))) (foreach e (vl-remove-if-not '(lambda (x) (<= (abs (- (cdr (assoc 40 (entget x))) 3.5)) 0.01)) (mapcar 'cadr (ssnamex ss))) (entdel e)))
Message 13 of 16
sanjayph1111
Please find reference attached AutoCAD DXF file, so that you can find the issue in this...
Message 14 of 16
sanjayph1111
Perfect...
It's now working to delete all 7mm dia circles...
Thanks a lot... 🙂
Message 15 of 16
cadffm
The previous code deletes all 7units dia circles,
tha last code delete all 7units dia circles and circle with dia near to 7units.
Sebastian
Message 16 of 16
Brock_Olly
The code *was* working, your circles were not exactly 7mm..
