Connecting Lines in 3D
Message 1 of 10
I'm attempting to make beams and columns. How do I make the lines one object. The beams have a notch in them and I am now trying to make it one object. It's been 12 years since I've used autocad and I'm a little rusty. Thanks
Mike
Replies (9)
Message 2 of 10
Try making the objects you have into a Region by typing 'REG' or 'REGION' in the command bar, then make them a Union by typing 'UNI' or 'UNION' into the command bar.  IT definitely works for 2D objects.  Should work for 3D but it could get funky.  (make sure the polylines are completely closed first)
Message 3 of 10
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Without seeing your drawing I am guessing here but I think a simple JOIN command will let you make all of the  lines into a single object.
If you want to share your drawing I am happy to take a closer look.
John Vellek
Message 4 of 10
Tried Join and it only joined certain segments not all. Tried Regen, no luck, tired union, no luck...
Message 5 of 10
Tried both of those....No luck
Message 6 of 10
john.vellek
HI @Anonymous,
Do the endpoints of the lines actually exist in the same location? Try increasing the accuracy  in UNIS and then look at properties of each line. Make sure that the endpoints have the same x,y, anz locations. Can you share a sample file?
John Vellek
Message 7 of 10
Sure here it is in all it's simplicity. Thanks
Message 8 of 10
john.vellek
HI @Anonymous,
I exploded the lines you already had connected and then ran OVERKILL to remove duplicate lines.  Now when I use join I can select the desired lines and they connect just fine. However, you will see there are limitations to Join by the image:
So, I wonder if you would consider using 3D solids to make this geometry instead which would let you use UNION?
They are fairly easy to work with and would give you better visibility and control I think.
I made a quick video that shows how you can use a closed polyline to define your beam and then Presspull it into the proper thickness.
I hope this helps.
John Vellek
Message 9 of 10
john.vellek
HI @Anonymous,
Did you take a look at the video I provided? I am hoping it helped you with the 3D construction. If so, please mark my post as a Solution. If not, Please let me know what additional questions you might have on this issue.
John Vellek
Message 10 of 10
Thanks so much! That helped and I learned something.
