AutoCAD Forum
Connecting 3D objects on an Elliptic Line
12 REPLIES 12
Message 1 of 13
917 Views, 12 Replies
Hi! I'm trying to finish this step but I'm unsure how to do it. I'm trying to connect two pieces together with an elliptic line, but I have no idea what to do.
The original and my version are embedded.
Labels (1)
  • 3d
12 REPLIES 12
Message 2 of 13
Patchy
Draw an ellipse inside the pipe and LOFT the 2 ellipses
Message 3 of 13
in reply to: Patchy
Oh it's a lot closer, but how do I make the loft retain the radius? When I try it just goes through a straight path between the two ellipsoids.
Message 4 of 13
Patchy
Loft and pick the 2 ellipses, ENTER, then use GUIDES, pick the two arcs.
Message 5 of 13
It should be working fine, but for some reason it just doesn't work for me. I don't understand why. I sent a video showing what's going on.
Message 6 of 13
Valentin-WSP
@Anonymous ,
Show us  what the command line says.  Also, optimize the drawing by doing an AUDIT.
Hopefully this helps.  Otherwise, post your drawing.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 7 of 13
Patchy
Probably the arcs are not precisely snapped to the quadrants.
Can you attach your .dwg ?
Message 8 of 13
in reply to: Patchy
I'm gonna be honest, I'm pretty sure that's the problem. I don't really know how to make the arc command work in this instance so my friend told me to do an alternative method that wasn't exact, since he didn't know how, either. How would I go about doing it right?
Message 9 of 13
in reply to: Valentin-WSP
Select guide profiles or [Join multiple edges]:
Modeling Operation Error:
Error Code Number is 114036
The selected entities are not valid.
Message 10 of 13
Patchy
Bad connection at the top quadrant.
Message 11 of 13
Patchy
in reply to: Patchy
After that SLICE using a surface. Finish it by using UNION command.
Message 12 of 13
I got it, thank you guys!
But quick question, on the 2D side, how would I go about doing the arc correctly?
Message 13 of 13
Patchy
The dimensions given wasn't correct.
They were near but not precise at the North and South quadrants,  you have to use grips and snap to the ellipses
to make LOFT works.
Technology Administrators
