Command line : Specify opposite corner or [Fence/WPolygon/CPolygon]: why ?
Message 1 of 15
Command line always says "specify opposite corner"
Good day, i've been working ith my autocad, and in the last 2 days, the command line says "specify opposite corner", eventhou i haven't selected a command, so i don't know why that legend appears, could you help me to solve this because its really anoying, and i can't work really good
Replies (14)
Message 2 of 15
jayhar
Hi @Anonymous
Similar Post Click Here
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
JAYHAR.M.J
Asst: Team Leader
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 3 of 15
j.palmeL29YX
Deselect "Implied Windowing". (see pic)
Jürgen Palme
Message 4 of 15
imadHabash
Hi and Welcome to AutoCAD Forum,
is there any outsource plug-ins or lisps that installed ? you may need to check that .
Imad Habash
Message 5 of 15
thank you so much ! I will check it !
Message 6 of 15
j.palmeL29YX
Would you please tell us more detailed what caused your problem and how did you solve it? It will help others with the same issue in the future.
THX
Jürgen Palme
Message 7 of 15
Kent1Cooper
@Anonymous wrote:
... the command line says "specify opposite corner", eventhou i haven't selected a command....
That's what happens when you pick a point in open space with no command active.  It assumes you are selecting things in noun-verb operation with a window of some kind.  If this is only first thing  in any drawing, and if you are not  picking yourself, something must be triggering the equivalent of a mouse pick when you open a drawing.  It's possible you just have a faulty mouse that's sending out a pick signal unintended somehow -- try a different one.
Kent Cooper, AIA
Message 8 of 15
Thank you very much for helping me! I will learn about it!
Message 9 of 15
hadarshaul9
Observer
Observer
Hi
I have this problem also !
I cant change it ..!
How can i cancel it??
please help me
Message 10 of 15
imadHabash
it will be nice if you make a new post and show us a screenshot for what you see in CAD screen ?
Imad Habash
Message 11 of 15
me too! can you help me?
Message 12 of 15
mwieczorek84DJB
Community Visitor
Community Visitor
Hello everyone, I had the same problem you all described. In addition my zoom/pan felt different too ... . However in others files all worked just fine.
Then I checked the ViewCube -> RightClick : In someway it was set to perspective. I changed to parralel as in my other files. All back to normal :).
Hope it works for you guys.
Message 13 of 15
harshit_gajjar
Community Visitor
Community Visitor
it is because you have another overlapping or empty viewport, simply delete those extra viewports to fix your issue.
Message 14 of 15
radhikaKPGRM
Community Visitor
Community Visitor
Hello, I have been facing this same situation past 1 week, checked everywhere but no answers i received. it will be so much thankful someone please address this issue and troubleshoot this.
Many Thanks!
@radhikaKPGRM - this post is being edited to remove PII.
Message 15 of 15
pendean
Community Legend
Community Legend
@radhikaKPGRM wrote:
Hello, I have been facing this same situation past 1 week...
So what changed with your PC or software in the last week?
Did your restart your PC yet?
Is your AutoCAD fully updated? We will need to see proof, a screenshot of your ABOUT command is a good place to start.
