object transparency
object transparency
Message 1 of 22
object transparency
Why am I unable to print transparent objects as transparent?
Replies (21)
Message 2 of 22
cadffm
1. Check your PAGESETUP (or Plotdialog) - Option "Plot transparency" checked?
2. Check your PLOTTRANSPARENCYOVERRIDE setting.
Sebastian
Message 3 of 22
a. Yes, Plot transparency is 'checked'
b. PLOTTRANSPARENCYOVERRIDE is set to '1'
Message 4 of 22
Alfred.NESWADBA
Some questions
  • is it drawing dependent (or does that happen with a new drawing too)?
  • is it printer dependent (which printer did you try, also test it using e.g. "AutoCAD PDF (General documentation).pc3)
  • which version of AutoCAD do you have (please show us a screenshot of command/dialog _ABOUT)
...if nothing helps, please upload the dwg-file.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 22
cadffm
Please create a small sample dwg, create a 90% transparence SOLID in modelspace,
set up your model pagesetup to use 'DWG to PDF.pc3' and using transparency an no plotstyletable.
create a PDF from there and upload your DWG + your PDF result and we can check both files and settings.
What is you productversion?
Command: _VERNUM
Sebastian
Message 6 of 22
  • it seems to be happening on other drawings too, not just this one
  • I've tried plotting 'dwg to pdf' but the problem's still there
  • I am using ACad 2015. Sorry, I don't understand what screenshot i need to share
Message 7 of 22
Here is the dwg file attached. I need the glass windows and floors to be transparent
Message 8 of 22
Alfred.NESWADBA
Please start AutoCAD with a new drawing, start command _ABOUT ... this shows a dialog with the exact product and version information. Please create a screenshot from that dialog and show it to us.
- alfred -
Alfred NESWADBA
Message 9 of 22
Alfred.NESWADBA
as we don't have the CTB file (and so can't reproduce the same as you have) select "none" in your setting for plot style table in the plot dialog.
Also a bit strange, which sense could it make to create a hatch with pattern "AR-RROOF" as transparent? The lines are so wide and nothing behind that to see if it is transparent or not.
Also you have splitted lines as visible and invisible ones ... why, if one line is partly behind a transparent object, why then splitting the line ... like this:
In general, transparency makes most sense for filled areas, not for lines, so for pattern "SOLID" as hatch ==> OK, but for hatch patterns which are also just lines, and they might cross lines behind the hatch you have just the crossing point where you might see that the hatch line is transparent over the background line.
[EDIT] have not understood in the first look that these are tricky viewports 😉 [/EDIT]
Also take care (as your design is just 2D), an object can only show transparency if it "above" another object, for your 2D-design you need to make sure with command _DRAWORDER that the correct objects are "in front".
If you want to discuss a specific position in your dwg file then please copy your file, delete all except 2 or 3 objects and upload this drawing with the description what you get and what you expect. This drawing here contains too many objects to discuss anything in detail.
- alfred -
Alfred NESWADBA
Message 10 of 22
Alfred.NESWADBA
sorry again for first not seeing your 3D-content 😉
Wouldn't transparency work better when shaded?
(I have changed all none-transparent layers to grey, so this differs a bit to your concept, but the green and red objects, which are on transparent layers, are also transparent in this visual style)
- alfred -
Alfred NESWADBA
Message 11 of 22
_VERNUM = "J.210.0.0 (UNICODE)" (read only)
Message 12 of 22
You're right about the hatches not needing to be transparent. They aren't.
The line-splitting i did because i wanted the glass to appear partially transparent- i needed that. Hence the line (floor edge) is drawn in a lighter shade behind it.
My problem is not with hatches or filled areas. It's with solid objects themselves. Like the glass windows and floors.
I will make a new file with less objects and send it
Message 13 of 22
I prefer using the 'hidden' style.
However, your screenshot shows how the model appears in model space. It hasn't been plotted. That's what I am having trouble with.
Message 14 of 22
I want to add- I print in the paper space, where i can choose Shade plot 'Legacy hidden'. This gives me a great unpixelated plot.
Message 15 of 22
Message 16 of 22
Attached is a smaller 3d model
Message 17 of 22
Alfred.NESWADBA
Well, but they (at least some) are sitting on a layer with transparency.
Your upload does not contain the referenced JPG's, so we can't see them (and I guess we should see them as you named them like "...transparent ... problem ...JPG")
To make it easier ... I have created a new drawing with just 2 solids and 4 viewports with different settings.
Look to that, play with the layer transparency settings and see if you can find a visual style + transparency setting + plot settings which match your needs.
If nothing matches, then please let us continue with that more easy drawing (so no need to describe with hundreds of objects which objects A in front of object B does not look well). modify that drawing, send it back and please describe what you expect.
I have also attached a PDF that shows how it looks like on my system, in case you get different results we might need to look more into your AutoCAD settings than into the settings of your dwg-file.
- alfred -
Alfred NESWADBA
Message 18 of 22
SEANT61
I don't think Legacy Hidden allows working with transparency in that fashion.  If true, some 'composite' technique (similar to what you have already done) may be required to achieve that glass effect.
May your cursor always snap to the location intended.
Message 19 of 22
SEANT61
Here's a quick composite.  The glass 3dSolids needed separate processing, then the light green solid hatch was used as an underlay - hence no transparency at all.
If the PDF printer allows, a similar technique could be used to add transparent hatches as overlays.
Message 20 of 22
This looks good!
What shade plot did you use?
I still haven't been able to get the glass objects to plot as transparent.
