Command line and FILETAB on same line
csalvian
csalvian
Hello everyone,
Interesting question for everyone: How do I get the command line and the open file tab to be on the same line?
Back story: I have two profiles in AutoCAD...one for vanilla autocad and one for my fire sprinkler software. In the fire sprinkler profile, the command line and the filetab are on the same line, saving me vertical screen real estate in my setup, like this ('ve made the AutoCAD window smaller, that's why the menubar is showing on 2 lines...when AutoCAD is maximised the menubar is only a single line):
Up until 2 days ago, I had the same layout in my vanilla AutoCAD profile setup. But then something changed and now I've got the command line and the file tab on 2 different lines, which takes up an extra line of vertical screen real estate, like this:
Does anyone know what system variable or setting in the CUI that I need to change to get it back to the single line layout?
Thanks in advance for the help.
Chris
pendean
Community Legend
Community Legend
Variable? That's a need trick.
csalvian
When I try to drag the command line onto the same line as the filetab, it shows like this:
But then when I release the mouse button, it just puts the command line above the filetab like it showed in the other picture.
ВeekeeCZ
What you had before was pretty odd and I never saw docked panel like this before.
Being that possible would be a good feature!
