a problem in conversion from dwg file to pdf file
when i convert an auto cad drawing to a pdf file, the pdf file drawing doesnot appear clearly.Untitled.pngUntitled2.pngUntitled3.pngUntitled4.pngUntitled5.png
Alfred.NESWADBA
Can you use PDF Options inside the plot dialog and raise the resolution, does that help?
If not ... we don't see your drawing, not your PDF, can you please upload both, dwg and pdf, so we can look into them?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
i attached the photos and i will attach here again.
Alfred.NESWADBA
In the photos I can't see what means "doesnot appear clearly" in the PDF.
I don't see which geometry types you have in your drawing, which settings (lineweight, size of geometry, scaling, ...) is used to plot. Photos/Screenshots could help to know what you mean by "not appearing clearly", but all the other information is only visible inside the dwg-file.
Imaging if you can see on a photo why an engine might not start ... I guess you need access to the engine, not just photos. 😉
- alfred -
Alfred NESWADBA
