Hello
Even it isn't possible to overpass the dialog box of the command "FLATSHOT", I would like to know if it is possible to record the setting of the dialog box. I program in VBA
Christophe
try the code here:
this thread is better since it uses VBA:
Solved: Does anyone know how to set origin when using flatshot? - Autodesk Community - AutoCAD
Thank you for everyone. I succeed to make loop despite the presence of the window. I have to press "create" at each loop
glad you found a solution...cheers!!!
