Center point reference missing when modifying
p_sydney_a_tse
Message 1 of 9
p_sydney_a_tse
Does anyone have the same problem and/or know how to resolve it? Thank you!
Replies (8)
Message 2 of 9
paullimapa
Are you referring to the center point of a Circle?
Paul Li
IT Specialist
@The Office
Message 3 of 9
p_sydney_a_tse
@paullimapa Circle, polygon, any geometrical shapes.. also when I use the polyline tool to draw a rectangle, once I finish my first two lines, my third line wouldn't look for the start of my first line as a reference... I don't know what is happening but apparently the reference points are not functioning properly or could it be turned on/off??
I hope you understand what I'm referring to. I just started learning this week. Still a newbie so not so good at describing tools and functions. Many thanks!
Message 4 of 9
paullimapa
Are you referring to object snaps?
Paul Li
IT Specialist
@The Office
Message 5 of 9
p_sydney_a_tse
@paullimapa You can see here - the end of the thrid line is not looking for the start of the first line (top horizontal line) on the horizontal axis
Message 6 of 9
p_sydney_a_tse
@paullimapa This is my current setting
Message 7 of 9
paullimapa
Check out this video on learning how to use object snap tracking
Paul Li
IT Specialist
@The Office
Message 8 of 9
cadffm
"wouldn't look for the start of my first line as a reference"
You can do it by
Turn on your PERpendicular snap or your otrack [F11]
hover your cursor on the 1st poly point, wait for the green +, drag down your cursor..
Sebastian
Message 9 of 9
p_sydney_a_tse
I turned it off and on again and the green dot does appear! But once I finished the modification I had to turn it off and on again for the green dot to appear again. Strange.
