Nachricht 1 von 9
- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Melden
Does anyone have the same problem and/or know how to resolve it? Thank you!
Gelöst! Gehe zur Lösung
Are you referring to the center point of a Circle?
@paullimapa Circle, polygon, any geometrical shapes.. also when I use the polyline tool to draw a rectangle, once I finish my first two lines, my third line wouldn't look for the start of my first line as a reference... I don't know what is happening but apparently the reference points are not functioning properly or could it be turned on/off??
I hope you understand what I'm referring to. I just started learning this week. Still a newbie so not so good at describing tools and functions. Many thanks!
Are you referring to object snaps?
@paullimapa You can see here - the end of the thrid line is not looking for the start of the first line (top horizontal line) on the horizontal axis
Check out this video on learning how to use object snap tracking
"wouldn't look for the start of my first line as a reference"
You can do it by
Turn on your PERpendicular snap or your otrack [F11]
hover your cursor on the 1st poly point, wait for the green +, drag down your cursor..
Sebastian
