Can someone give a simple work through on combining a GeoTIFF file and a DXF file? Thanks for your help
Solved by TerryDotson. Go to Solution.
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I am not sure exactly what you are looking for but start by opening the DXF in AutoCAD and then saving it as a DWG file. Then attach your image.
Can you share your files so I can better understand what you are asking?
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved. If you can provide some files that you are trying to work with that would be most helpful.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Note that plain AutoCAD does not provide the means to complete step 2, you will need Civil3D or an add-on.
