AutoCAD Forum
Circles in 3d Visual Style "Realistic" Show as Dodecagons
4 REPLIES 4
656 Views, 4 Replies
Any idea why my circles are displaying in 12 segments in AutoCAD 2020, using Visual Style “Realistic?” Some screenshots and the actual .dwg attached if it helps, and a copy/paste of the tuner log. It is a real circle, extruded along an arc path.
Also, since the screenshots, I changed Contour Lines to 2047, and 2DRETAINMODE to 0. I've also tried VIEWRES both with and without Fast Zoom, and at various values up to 20,000.
Aeran
Tuner Log:
Driver version: 26.21.14.3179
Tuning Date:
Virtual device: Dx11 (Hardware)
                The card and driver does not meet the minimum requirement.
Display Adapters:
                Intel(R) UHD Graphics 630(Primary)
Certification:
                Feature Mode                   3
                Feature Mode Available 120
                Config Level                       3
                Hardware Available         True
                Hardware Recommended            True
                Status                  5
                Hardware ID                      2
                Hardware Feature Level 1
                Software Feature Level 1
General Options:
                Adaptive Degradation                   True
                Discard Backfaces                           True
                Dynamic Tessellation                     True
                Generate Vertex Normals            False
                Handedness                    Right
                Maximum LODs                               6
                Redraw on Window Expose         True
                Surface Tessellation Tolerance   92
                Transparency                  MediumQuality
Additional System Information:
                ComputerSystem
                                Manufacturer                    Dell Inc.
                                Model                  Latitude 5401
                                NumberOfProcessors     1
                                TotalPhysicalMemory    xxx-xxxxxxxx
                Processor
                                MaxClockSpeed               2592
                                Name                                  Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz
                                NumberOfCores              6
                                NumberOfLogicalProcessors       12
                                Revision
                OperatingSystem
                                Name                                  Microsoft Windows 10 Business|C:\windows|\Device\Harddisk0\Partition3
                                OSLanguage                      1033
                                ServicePackMajorVersion            0
                                ServicePackMinorVersion            0
                                TotalSwapSpaceSize
                                TotalVirtualMemorySize               66885796
                                Version                               10.0.18362
                DiskDrive
                                Model   Micron 2200S NVMe 512GB
                                Name    \\.\PHYSICALDRIVE0
                                Size        512105932800
                DesktopMonitor0
                                MonitorManufacturer   (Standard monitor types)
                                MonitorType                     Generic PnP Monitor
                                Name                  Generic PnP Monitor
                                ScreenHeight
                                ScreenWidth
                DesktopMonitor1
                                MonitorManufacturer
                                MonitorType                     Default Monitor
                                Name                  Default Monitor
                                ScreenHeight                     1080
                                ScreenWidth                     1920
                DisplayConfiguration
                                DeviceName      Intel(R) UHD Graphics 630
                                DisplayFrequency            60
                                DriverVersion
                                PelsHeight          768
                                PelsWidth           1024
                VideoController0
                                AdapterDACType                            Internal
                                AdapterRAM                    1073741824
                                ConfigManagerErrorCode             0
                                CurrentHorizontalResolution      1920
                                CurrentVerticalResolution            1080
                                DriverDate                        20190925000000.000000-000
                                DriverVersion                   26.20.100.7262
                                InstalledDisplayDrivers    C:\windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_50beeae19460b35e\igdumdim64.dll,C:\windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_50beeae19460b35e\igd10iumd64.dll,C:\windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_50beeae19460b35e\igd10iumd64.dll,C:\windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_50beeae19460b35e\igd12umd64.dll
                                Status                                 OK
                                TimeOfLastReset
                                VideoArchitecture          5
                                VideoModeDescription                 1920 x 1080 x 4294967296 colors
                VideoController1
                                AdapterDACType                            Integrated RAMDAC
                                AdapterRAM                    2147483648
                                DriverDate                        20190814000000.000000-000
                                DriverVersion                   26.21.14.3179
                                InstalledDisplayDrivers    C:\windows\System32\DriverStore\FileRepository\nvdm.inf_amd64_206d8a350e28384b\nvldumdx.dll,C:\windows\System32\DriverStore\FileRepository\nvdm.inf_amd64_206d8a350e28384b\nvldumdx.dll,C:\windows\System32\DriverStore\FileRepository\nvdm.inf_amd64_206d8a350e28384b\nvldumdx.dll,C:\windows\System32\DriverStore\FileRepository\nvdm.inf_amd64_206d8a350e28384b\nvldumdx.dll
                                Name                                  NVIDIA GeForce MX150
                                Status                                 OK
                                TimeOfLastReset
                                VideoArchitecture          5
Process Information:
                Loaded ARX and CRX Modules
                                acapp.arx
                                acapp.crx
                                acautoloader.crx
                                acautoloader.arx
                                acexperience.arx
                                acpublish.arx
                                acpublish.crx
                                AcPi.arx
                                acjscorestub.crx
                                acgsconfig.arx
                                acgsconfig.crx
                                acvmtools.crx
                                vl.crx
                                acblock.crx
                                acvdiff.arx
                                AcVDiff.crx
                                acsign.arx
                                acetutil.arx
                                vl.arx
                                acdim.arx
                                acdim.crx
                                AcFdUi.arx
                                acconnectwebservices.arx
                                acopm.arx
                                acobjclassimp.arx
                                AcOcSchemaUtil.arx
                                acopmext.arx
                                AcPEXCtl.arx
                                units.crx
                                units.arx
                                acvmtools.arx
                                acsecopt.arx
                                acsceneui.arx
                                AcCamera.arx
                                acsceneui.crx
                                acvisualstylesmanager.arx
                                actp.arx
                                acviewmgr.arx
                                acplotgui.arx
                                acpltstamp.crx
                                acpldetails.crx
                                acpldetails.arx
                                acdyninput.crx
Effects:
                ACAD_2DRetainMode                    supported           turned on
                ACAD_2DRetainModeLevel                     5          3
                ACAD_AdvancedMaterial             supported           turned on
                ACAD_FullShadows         supported           turned on
                ACAD_GLCoreProfile     not supported   turned off
                ACAD_GlowHighlighting                supported           turned on
                ACAD_GPUHatch             supported           turned on
                ACAD_GPULineType                       supported           turned on
                ACAD_LineFading            supported           turned on
                ACAD_LineSmoothing                    supported           turned on
                ACAD_PerPixelLighting  supported           turned on
                ACAD_TextureCompression        not supported   turned off
                ACAD_WhipArc                supported           turned on
Labels (1)
4 REPLIES 4
imadHabash
HI,
usually increasing FACETRES value will fix the issue and it's ok as shown in your attached image . from GRAPHICSCONFIG command :
  • try to Turn ON/OFF hardware acceleration .
  • select Smooth Line Display option .
Imad Habash
in reply to: imadHabash
Thanks imadHabash. Unfortunately I tried hardware acceleration both on and off, and Smooth Line Display both on and off, and unchecked some of the advanced shading settings as well, and none of that smoothed the circles.
imadHabash
as you can see from below image , you can from your Visual Styles Manager select isolines option from Edge Settings to your current Realistic visual style . then right click your navigation cube and select Parallel option . hope it's help .
Imad Habash
Thanks again imadHabash. That gets me the closest to a round circle!
Forma Design Contest
AutoCAD Beta
