AutoCAD Forum
Changing F12 settings
3 REPLIES 3
brockcorbin5
251 Views, 3 Replies
Is it possible to change your F12 settings (sorry, I am not sure what the function itself it is called).
For example, when drawing a polyline, I rather it display only the length of the new segment, and not the angle.
Is there a way to adjust this?
Thanks!
3 REPLIES 3
Patchy
in reply to: brockcorbin5
Change to do other task? sure.
it's done by using the CUI
Go to Youtube and search for many videos showing how.
brockcorbin5
in reply to: Patchy
Not quite what I meant; I want to change the properties of what F12 shows. Similar to how you can adjust Osnap to only snap to endpoint or nearest, etc.
I rather F12 only show the length of my line
cadffm
there are general settings only
Look at the DYNMODE setting 1-3
And to learn about all DYNAMIC INPUT settings, also the other topics.
There is not more custom settings for it.
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-0AA6E640-039A-4CAE-A161-64A5574E8AAB
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-38EC86CF-D96A-455F-A5DE-2CDA23C28FC4
Sebastian
Forma Design Contest
AutoCAD Beta
