Is it possible to change your F12 settings (sorry, I am not sure what the function itself it is called).
For example, when drawing a polyline, I rather it display only the length of the new segment, and not the angle.
Is there a way to adjust this?
Thanks!
Solved by cadffm. Go to Solution.
Change to do other task? sure.
it's done by using the CUI
Go to Youtube and search for many videos showing how.
there are general settings only
Look at the DYNMODE setting 1-3
And to learn about all DYNAMIC INPUT settings, also the other topics.
There is not more custom settings for it.
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-0AA6E640-039A-4CAE-A161-64A5574E8AAB
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-38EC86CF-D96A-455F-A5DE-2CDA23C28FC4
Sebastian
