Changing 2 drawings so they match coordinates
mbeattieMB7F8
Message 1 of 13
mbeattieMB7F8
I wondered if you could help. I have 2 drawings but when I copy and paste elements of one to another to original coordinates it pastes the wrong scale and wrong location.
When i point ID on one drawing also the coordinates are totally different. Is anyone able to help?
Cheers.
Replies (12)
Message 2 of 13
S.Faris
The reason might be "Differences in drawing units between source and target drawings"
Refer to this : Using the Clipboard pastes objects in the wrong size in AutoCAD
or use -DWGUNITS and make sure both the drawings are in same units(but don't scale).
SALMANUL FARIS
Message 3 of 13
mbeattieMB7F8
Tried that but still can't seem to get the two to match.
Message 4 of 13
S.Faris
when you use -DWGUNITS what s the value for "Unit for length" that you get in both your drawings?
eg:
Command: -DWGUNITS
Drawing units:
1. Inches
2. Feet
3. Millimeters
4. Centimeters
5. Decimeters
6. Meters
Unit for length <6>
SALMANUL FARIS
Message 5 of 13
rkmcswain
@mbeattieMB7F8  - so are you saying that you ID a common, known point in each drawing and you do not get the same coordinates? If so, _and_ both drawings are in WCS, then one of them must be in the wrong location.
R.K. McSwain     | CADpanacea | on twitter
Message 6 of 13
mbeattieMB7F8
Yeah that is basically it. Do you know how I change the drawing I am copying from as the one I am copying into is the right coordinates.
Message 7 of 13
rkmcswain
@mbeattieMB7F8 - do you have two or three, known, common points in each drawing? If so, you could insert (or Xref) one into the other, and use the ALIGN command to align those points. After that, explode (or in the case of Xref, bind and explode), and get rid of the data you don't need from the other drawing.
Message 8 of 13
pendean
Community Legend
Community Legend
Post your two DWG files, lets all have a look for ourselves.
Message 9 of 13
mbeattieMB7F8
Great thanks. Attached drawings. I need the Gas and Water drawings in the same scale/coordinates as the blank current site DWG drawing.
Message 10 of 13
ilia.borisov
Command "-DWGUNITS" -> Enter -> Enter... till Scale objects from other drawings upon insert? -> No.
Message 11 of 13
s.borello
You can use control shift c to copy to clipboard with a base point... then paste to the same base point in your other drawing, this way the coordinates won't matter.  If you really need them to be the same coordinates, why not xref drawing 1 into drawing 2 and align them that way.
Message 12 of 13
aecivil1
Community Visitor
Community Visitor
What if we don't have a common point in the two layouts. we only have northing and easting in both the drawings taken from same reference points.
Message 13 of 13
Pointdump
Hi Deepak,
Welcome to the Autodesk Forums.
It would be best to start a new thread with your question. And please post screen shots, or better yet, post both drawings.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
