Color Change when converting to PDF (with Print to PDF)
I have an Issue that a logo is changing color when i converting to PDF. It´s as if one of the color is just made white.
I have tried rebuilding and recoloring the logo.
Maybe i should rebuild it as one-layer witherout any overlay?
Alfred.NESWADBA
turn your modelspace background in AutoCAD to white, so you can really compare these 2 screenshots.
Transparent objects in front of black look different to the same objects with white background (independent of AutoCAD).
Grey values are inverted when having black/dark or white/light background ... so not easy to compare.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
It worked by remaking the logo without any overlays. I just used paint the get the RGB code for the area where the white is partly transparent.
Alfred.NESWADBA
Having an RGB value and then making something transparent means the background color influences the result, this is why I asked to switch your AutoCAD to white background, otherwise you could never compare these screenshots.
- alfred -
Alfred NESWADBA
