Changes to one object effecting all other snapped objects. (Grip editing)
I seem to have changed a setting that is making any change to one object effect any other objects that are snapped onto its vertices. For example, if I have two "LINE" objects snapped end to end and I try to "MOVE" one of them, the other will begin stretching as though I had selected its grip.
I can cycle this behavior off with the Shift key while a command is active but I can't do that every time I want to edit an object. I imagine there is just a System Variable that needs to be toggled but without knowing what it's called I can't find it.
Does anyone have any ideas?
@Anonymous, Welcome to the forums!
I looked around and found this thread(Link below)
Is this what is going on? I know about DIMASSOC but that's for dimensions. I'm honestly not sure about objects(other than dimensions) being associated with vertices from another object.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Stretching-or-moving-objects-moves-other-geometry-in-AutoCAD.html
That's exactly the issue! Thanks Devinhdl!
RobDraw
Change FSMODE to "0"?
Rob
imadHabash
Hi and Welcome to AutoCAD Forum,
>> if I have two "LINE" objects snapped end to end and I try to "MOVE" one of them, the other will begin stretching as though I had selected its grip. <<
i'm afraid that you have Parametric issue ( maybe ) .... would you please attache here your CAD dwg for testing ?
Imad Habash
