scale problem
scale problem
scale problem
H I am trying to custom make a scale in a Viewport in AUTCAD 2018...
The scale should be 1:1200  but once I create it and apply the scale to the VP  it zooms in too much so I see nothing of the drawing in the VP -  but I am following a mock exam tutorial so its correct what I'm doing but it doesn't work..
I wonder if I should go and adjust the drawing Units via the drawing utility setup first....
Any help would be much appreciated
Kind regards
Cad-learner
To get more information, to create this new scale you:
  • Went to scale list
  • added a new scale
  • named it 1:1200
  • kept paper units at 1
  • set drawing units to 1200
Now, you're saying that the VP zoomed too far in. Did you happen to set the paper units to 1200 and the drawing units to 1 instead of setting the paper units to 1 and drawing units to 1200?
If this didn't help or solve your issue can you attach the drawing so I can see how you set it up? You can strip out sensitive information if needed.
imadHabash
please try this in your VP : Zoom >> Scale >> 0.083333   and see if it's work .
Command: Z ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: s
Enter a scale factor (nX or nXP): .0833333
Imad Habash
