AutoCAD Forum
Change number of items in array
2 REPLIES 2
5899 Views, 2 Replies
Hi All,
I have an array, and I wan't to make it shorter --> Fewer items, I don't want to change the spacing between them or anything.
In the properties window I can't simply overwrite the item number, is there another way?
Regards
Tags (2)
2 REPLIES 2
Alfred.NESWADBA
when you have selected the array, look to the ribbon, it shows values you can change...
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
alex101000
Try to change Fill entire path to No at Properties window and after change numbers
Forma Design Contest
AutoCAD Beta
