Hi All,
I have an array, and I wan't to make it shorter --> Fewer items, I don't want to change the spacing between them or anything.
In the properties window I can't simply overwrite the item number, is there another way?
Regards
Solved by alex101000. Go to Solution.
when you have selected the array, look to the ribbon, it shows values you can change...
- alfred -
Try to change Fill entire path to No at Properties window and after change numbers
