AutoCAD Forum
change mouse wheel to pan
3 REPLIES 3
784 Views, 3 Replies
Hi, I've searched and searched an no method has helped. I've tried CUI command to change settings to pan. MBUTTONPAN to 0 & 1, neither work. control panel-mouse-wheel an the only option i'm given is the number of lines scrolled horiz & vertical... WHERE IS THIS MIDDLE MOUSE BUTTON DIAL LOCATED???
3 REPLIES 3
SeeMSixty7
Are you using Mouse button mapping software? Some mouse drivers have the ability to map buttons to a different command and the scroll wheel may not be sending the Middle button signal.
in reply to: SeeMSixty7
I figured out that the contact point in the wheel was the issue.
thanks
SeeMSixty7
Gotta love Hardware problems, at least those are pretty easy to fix.
Forma Design Contest
AutoCAD Beta
