AutoCAD Forum
change mouse wheel to pan
3 REPLIES 3
809 Views, 3 Replies
Hi, I've searched and searched an no method has helped. I've tried CUI command to change settings to pan. MBUTTONPAN to 0 & 1, neither work. control panel-mouse-wheel an the only option i'm given is the number of lines scrolled horiz & vertical... WHERE IS THIS MIDDLE MOUSE BUTTON DIAL LOCATED???
3 REPLIES 3
SeeMSixty7
Are you using Mouse button mapping software? Some mouse drivers have the ability to map buttons to a different command and the scroll wheel may not be sending the Middle button signal.
in reply to: SeeMSixty7
I figured out that the contact point in the wheel was the issue.
thanks
SeeMSixty7
Gotta love Hardware problems, at least those are pretty easy to fix.
AutoCAD Inside the Factory
