didn't work
i cant write 2
when i select the objects on copy its doesnt show the highlight
But what I can't believe 🤔
Plrase show Scrrenshot of whole program window after type in
Command: DRAGMODE
Sebastian
so what is the right commned?
here
In you other post you were told to set HIGHLIGHT to 0. Set it back to 1 and set SELECTIONEFFECT to 1 also.
Who messed with your Autocad?
Try all of these:
PICKDRAG
DRAGMODE
PICKFIRST
HIGHLIGHT
and see how they were made to work.
didn't work 😞
Are you saying you don't have the "selection preview"?
If that's the case, click the "Big Red A" and select options, then go to the "Selection" tab, and check all of the options you want to use. It may take some experimentation to get what you want and turn off what you don't.....see attached for example.
Hope this helps, if not, can you be more specific?
well i tried every one of them and it didnt work
AUTO means 2, so use AUTO
but it is set on AUTO.
So dragmode isn't the problem.
Important: Please run all test with simple objects only!
LINE or CIRCLE, nothing else.
Sebastian
Command: GRAPHICSCONFIG
turn on hardware acceleration OFF
try it
try it
I see it is a student version, so you are a new user?
then i have one question: Start MOVE command,
acad ask for object selection, do it
confirm/end th eobject selection,
acad ask for 1. Point...
type in: _NONE<enter>
then click with your cursor near to the object you want to move.
Still a problem?
Sebastian
this is a student virison and i have this progrem for about 8 months
i tried everything listed here
it stop to show the highlight when i fixed the dotted line problem
so its new
so its new
Well then the solution should be pretty easy, UNDO whatever you did when you "fixed the dotted line problem"
If you still can't get it, then PLEASE ...... download and install SCREENCAST and make a screencast so we can SEE the problem and what values all of the relevant SYSTEM VARIABLES are set to. Help us to help you.
