cant see objects selcted on autocad while copy
Message 1 of 21
Replies (20)
Message 2 of 21
user181
Try setting DRAGMODE to  Auto or On
Message 3 of 21
didn't work
Message 4 of 21
rkmcswain
Set DRAGMODE to "Auto" (or 2), not "On".
Message 5 of 21
i cant write 2
Message 6 of 21
cadffm
Then you have start the wrong command.
Sebastian
Message 7 of 21
when i select the objects on copy its doesnt show the highlight
Message 8 of 21
cadffm
But what I can't believe 🤔
Plrase show  Scrrenshot of whole program window after type in
Command: DRAGMODE
Sebastian
Message 9 of 21
so what is the right commned?
Message 10 of 21
here
Message 11 of 21
user181
In you other post you were told to set HIGHLIGHT to 0.  Set it back to 1 and set SELECTIONEFFECT to 1 also.
Message 12 of 21
Patchy
Who messed with your Autocad?
Try all of these:
PICKDRAG
DRAGMODE
PICKFIRST
HIGHLIGHT
and see how they were made to work.
Message 13 of 21
didn't work 😞
Message 14 of 21
Are you saying you don't have the "selection preview"?
If that's the case, click the "Big Red A" and select options, then go to the "Selection" tab, and check all of the options you want to use. It may take some experimentation to get what you want and turn off what you don't.....see attached for example.
Hope this helps, if not, can you be more specific?
Message 15 of 21
Patchy
Did it work before? Why don't you try tweaking your graphic card.
Message 16 of 21
well i tried every one of them and it didnt work
Message 17 of 21
cadffm
AUTO means 2, so use AUTO
but it is set on AUTO.
So dragmode isn't the problem.
Important: Please run all test with simple objects only!
LINE or CIRCLE, nothing else.
Sebastian
Message 18 of 21
cadffm
Command: GRAPHICSCONFIG
turn on hardware acceleration OFF
try it
try it
I see it is a student version, so you are a new user?
then i have one question: Start MOVE command,
acad ask for object selection, do it
confirm/end th eobject selection,
acad ask for 1. Point...
type in: _NONE<enter>
then click with your cursor near to the object you want to move.
Still a problem?
Sebastian
Message 19 of 21
this is a student virison and i have this progrem for about 8 months
i tried everything listed here
it stop to show the highlight when i fixed the dotted line problem
so its new
Message 20 of 21
rkmcswain
so its new
Well then the solution should be pretty easy, UNDO whatever you did when you "fixed the dotted line problem"
If you still can't get it, then PLEASE ...... download and install SCREENCAST and make a screencast so we can SEE the problem and what values all of the relevant SYSTEM VARIABLES are set to.  Help us to help you.
