AutoCAD Forum
Cannot remove datalink
20 REPLIES 20
Message 1 of 21
pixelarch
75313 Views, 20 Replies
Dear All,
I cannot remove datalink was created by Insert Sheet List Table. Cannot see it in Datalink Manager.
Please see the attach.
Thanks.
20 REPLIES 20
Message 2 of 21
Does this help?
http://ltunlimited.typepad.com/my_weblog/2010/09/detach-data-link-from-table.html
Kate Morrical
Digital Design Manager, Washington DC
BIMmuse.com
Message 3 of 21
It doesnt work in this case. I cannot see it in Datalink Manager.
Message 4 of 21
maxim_k
in reply to: pixelarch
Please look also here:
http://www.cadtutor.net/forum/showthread.php?48655-How-to-completely-delete-a-table-data-link
Maybe you will be able to remove datalink with Lisp?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 21
TrevN
Explode the table, then delete / detach datalink.
Done.
Message 6 of 21
pixelarch
in reply to: TrevN
Dear TrevN,
I give it a try but doesn't work.
Message 7 of 21
pixelarch
It worked Maxim_k
Thanks all.
Message 8 of 21
Any solution? Not working with AutoCAD LT.
Message 9 of 21
Delete or change the name of the data link file > copy and paste this into the command line
(dictremove (namedobjdict) "ACAD_DATALINK")
Save>Close>Reopen the drawing
Message 10 of 21
Thanks Badams, that worked perfect for me.
Message 11 of 21
I typed in "datalink" and it came up.
thanks Kate!Smiley Wink
Message 12 of 21
kirk.potter
This works on AutoCAD Architecture 2018, but it wasn't this simple on older versions.
Thanks Kate! I love it when people take time to post the Simple Easy Fix.
Command: datalink <ENTER>
Right-Click the "datalink" you want to remove
Click "Delete"
Thanks again,
Kirk A. Potter
Message 13 of 21
kirk.potter
(This process worked for AutoCAD Architecture 2018...it's probably worth a shot)
Data Links must be disconnected from the tables in the DWG, before they can be removed.
1.) Click in any CELL of the table with the datalink associate to it
2.) Right-click on table, and select "Data Links">"Detach Data Links"
3.) Click <Yes> to detach the link from the table
4.) Click Out of the table to avoid changing the text
5.) On the Command line, type DATALINK to open the "Data Link Manager"
6.) Right-click the datalink you want to remove
7.) Click <Yes>
*NOTE: If you cannot find the table that is connected to the data link you wish to remove, remember to check your "Frozen" layers and the layers that may be turned "Off". Otherwise, a "PURGE" may do the trick.
I hope this is helpful.
Kirk A. Potter
Message 14 of 21
in reply to: maxim_k
It worked for me too.
The table link could be a nightmare, when we forget some steps.
Thank you.
Message 15 of 21
sharpl
God to love solid answers, thank you! Worked for 2017 like a clock Woman Happy
Message 16 of 21
Seth007
Using above method works, but this deletes all data-links. Is there a way to delete the data link giving its name?
Message 17 of 21
citemgr
many thanks - that worked!
Message 18 of 21
wesley
Thank you! The command you posted worked great. I've been scratching my head how to delete data links for a very long time (literally months). Thanks again.
Message 19 of 21
This worked for me on Autocad LT
Message 20 of 21
changmarin
Experienced the same problem.  Solved it invoking DATALINK command and deleting Excel Links from the Links List.
Ch.-
Forma Design Contest
AutoCAD Beta
