Dear All,
I cannot remove datalink was created by Insert Sheet List Table. Cannot see it in Datalink Manager.
Please see the attach.
Thanks.
Solved by maxim_k. Go to Solution.
Please look also here:
http://www.cadtutor.net/forum/showthread.php?48655-How-to-completely-delete-a-table-data-link
Maybe you will be able to remove datalink with Lisp?
Maxim
Delete or change the name of the data link file > copy and paste this into the command line
(dictremove (namedobjdict) "ACAD_DATALINK")
Save>Close>Reopen the drawing
This works on AutoCAD Architecture 2018, but it wasn't this simple on older versions.
Thanks Kate! I love it when people take time to post the Simple Easy Fix.
Command: datalink <ENTER>
Right-Click the "datalink" you want to remove
Click "Delete"
Thanks again,
Kirk A. Potter
(This process worked for AutoCAD Architecture 2018...it's probably worth a shot)
Data Links must be disconnected from the tables in the DWG, before they can be removed.
1.) Click in any CELL of the table with the datalink associate to it
2.) Right-click on table, and select "Data Links">"Detach Data Links"
3.) Click <Yes> to detach the link from the table
4.) Click Out of the table to avoid changing the text
5.) On the Command line, type DATALINK to open the "Data Link Manager"
6.) Right-click the datalink you want to remove
7.) Click <Yes>
*NOTE: If you cannot find the table that is connected to the data link you wish to remove, remember to check your "Frozen" layers and the layers that may be turned "Off". Otherwise, a "PURGE" may do the trick.
I hope this is helpful.
Kirk A. Potter
Using above method works, but this deletes all data-links. Is there a way to delete the data link giving its name?
Thank you! The command you posted worked great. I've been scratching my head how to delete data links for a very long time (literally months). Thanks again.
Experienced the same problem. Solved it invoking DATALINK command and deleting Excel Links from the Links List.
