When i tried to delete "Standard" multileader style it says style in use. But I could not found any object which has that multileader style.
My drawing is completely empty and I want to make it standard drawing and template.
@Anonymous ,
If you are making a standard drawing and template, just Modify the Standard Multileader style in AutoCAD.
Otherwise, you could use QSELECT to find and delete any styles.
Consider this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
This is the default style .. you have to look to the other default styles in the drawing and start to cut the connection between those styles to be enabled to delete it .
Imad Habash
I have to multileader style. I made multileader style other than Standard as set current. Still I could not delete standard. How to find connection between other styles with Standard Style.
