Can't open drawing file
Message 1 of 12
Able to launch AutoCAD but can't open dwg files
Replies (11)
Message 2 of 12
Hello @Anonymous
Could you attach the .Dwg?
Message 3 of 12
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 Which version of AutoCAD do you have installed and on which operating system?  If you start AutoCAD can you create a new file?  Where are your files located? Are they stored locally?
John Vellek
Message 4 of 12
Hi John,
 Which version of AutoCAD do you have installed and on which operating system? AutoCAD 2017, Windows 10 If you start AutoCAD can you create a new file? No Where are your files located? on my hard drive  Are they stored locally?
Message 5 of 12
john.vellek
HI @Anonymous,
I am sorry to hear that you can't even start a new file.  Is this a new install? Or, has this been working until just recently?
Try a Reset Settings to Default to see if that will get you up and running.
John Vellek
Message 6 of 12
No, it was working last week. It was only this morning that it started to not work.
I have since uninstalled AutoCAD and re-installed it onto my computer. But the same issue is happening!
Can't select any of the options on the toolbar, when I move my mouse around the screen?
Message 7 of 12
john.vellek
Hi @Anonymous,
So, what happened over the weekend? Did you get some updates for Windows or perhaps security software? Did  a driver get updated?
Try running AutoCAD with the No Hardware option to see if that will let you launch the program normally.
John Vellek
Message 8 of 12
Can't select no commands from toolbar. Can't close out of AutoCAD. Only when I use task manager can I close AutoCAD?
Message 9 of 12
Might have gotten Windows update over the weekend?
Message 10 of 12
jayhar
Find the attachments you can solve it.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 11 of 12
john.vellek
Hi @Anonymous,
If you got some Windows updates, you can try removing those. Or, see if there are additional Windows updates that can be applied.
At a Windows command line, please type WINVER and give me the exact version that you are running. Please also check your Autodesk Desktop App or Account page to make sure that you have fully updated your AutoCAD.
Here is an article that describes these steps as well as others that might resolve the issue.
Please try logging into your computer as a new administrator user and see if AutoCAD 2017 launches properly. Please also try logging into your account to make sure that a license is being accepted.
John Vellek
Message 12 of 12
john.vellek
Hi @Anonymous,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail as requested in my last post on this issue so we can continue to work towards getting this solved.
John Vellek
