Can't find raster tools... Yes, I've read the other posts...
manjuo
3.458 Vistas
22 Respuestas
Mensaje 1 de 23
manjuo
It's the same issue, but everyone seems to this this: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/AutoCAD-...
solves something and it doesn't. Raster tools cuix or folder ARE NOT IN IN THE FREAKING DOWNLOAD!!!!!!!!!! I redownloaded 2020, installed 2021 and checked 2018. I'm using Mechanical and architectural, and neither of them have it.
Someone accepted "It's a separate download" as a solution to a thread. If so, where's the download location? Why would the education package give stress analyses and not raster design tools, and why does it SAY that it's included and students get it free. Who's accepting these solutions? Ar they actually trying or giving up, like I will be after this rant?
BUT, I do have Ltools commands which I read is a command to do something withraster tools, so they must be somewhere in there. Unfortunately, everyone references buttons and not commands I would also rather have the toolbar as well and  think it's stupid that everytime I use AutoCAD I waste hours on crap like this.
I think most people are doin what I am and after posting this doing it in GIMP and Inkspace, which I should have done in the first place.
0 Me gusta
3.459 Vistas
22 Respuestas
Respuestas (22)
Mensaje 2 de 23
Patchy
takes one minute to search and get it.
0 Me gusta
Mensaje 3 de 23
RobDraw
The OP or in a rare case a moderator will.
Posters usually mark a solution unless it actually works. It's got nothing to do with whether or not it will work for you but in this case, if it doesn't, you are probably missing something. It's been a long time since I've used Raster tools but, when I did, it was a different shortcut to get AutoCAD to start with it enabled. Maybe you will read this before you give up and maybe it will help you, maybe not. Either way, thanks for stopping by (just to dump a rant) and good luck.
Rob
0 Me gusta
Mensaje 4 de 23
manjuo
Thank you for your 2 s search. Now, try to actually download it from the download center. If you are able to do that, opposed to going to pages saying it's included in AutoCAD, as it says everywhere except for the one thread that said it's another download, then would it be possible to let me know HOW you actually installed it onto AutoCAD?
If you look at the link, you'll see there is a reported issue with the menu for the toolbar. But the solution there did no work for me. So I would love to hear your resolution. Maybe you can screencast the solution!
Thanks in advance!
0 Me gusta
Mensaje 5 de 23
ChicagoLooper
Enter MENULOAD on command line. Take a screenshot and upload it.
Chicagolooper
0 Me gusta
Mensaje 6 de 23
manjuo
@ChicagoLooper : Thanks for your interest. Here's what's happening so far. I don't know where to go from here....
 Menuload...
Customization files in ACAD Support folder
Folder structure for Autodesk where AeCco.cuix copy should be...
From https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
0 Me gusta
Mensaje 7 de 23
ChicagoLooper
  1. Go here:C:\Program Files\Autodesk\AutoCAD Raster Design 20XX\UserDataCache\Support
  2. Copy this to clipboard:AeCo.cuix
  3. Paste contents of the clipboaed here: C:\Users\<username>\AppData\Roaming\Autodesk\<product folder>\RXX.X\<language>\Support
  4. Restart AutoCAD
Chicagolooper
0 Me gusta
Mensaje 8 de 23
manjuo
Hi @ChicagoLooper
If you see the last picture in the previous message, you will see there is no folder in my programfiles autodesk folder called AutoCAD Raster Design. Or is it there and I don't see it? For those that start with AutoCAD I see:
AutoCAD 2018
AutoCAD 2020
AutoCAD 2021
And then the next one is
Autodesk AdSSO
Or is there somewhere else I am supposed to look?
0 Me gusta
Mensaje 9 de 23
manjuo
You will also see that I had copied the link to the page where you got that solution in the original message and right after the last picture of the one before you replied with the thing I just showed you I can't do.
0 Me gusta
Mensaje 10 de 23
manjuo
That is the problem.... If you have a solution for that, it would be great.
0 Me gusta
Mensaje 11 de 23
manjuo
Just in case I took a screenshot of the Autodesk folder in Program Files 86 so no one wastes our time asking me to check that folder..... 
0 Me gusta
Mensaje 12 de 23
ChicagoLooper
Wrong folder. That’s not the correct folder. You are skimming, not reading. If you are carefully reading the post then you’ d be looking in the right folder.
Opening the correct folder is not like buying a used car, it’s not negotiable. Either you’re in the right folder or you’re not.
Read the correct subfolder’s location and you'll be fine. Act like you already know which folder to open and you’ll fail.
Chicagolooper
0 Me gusta
Mensaje 13 de 23
manjuo
Before I get other suggestions I've already tried, please see the following proof:
That Raster Design is not loaded in my computer:
So I can't repair it.
That I have installed everything that AutoCAD comes with:
Regardless,  I tried and successfully "repaired" AutoCAD
That a search on the C disk for AeCo.cuix, as recommended by @ChicagoLooper, returns no matches.
That a search for AeCco.cuix, as recommended on https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/AutoCAD-...
also returns no matches:
If someone has the C:\Program Files\Autodesk\AutoCAD Raster Design 2021 folder maybe they can zip it and upload it? Then I can just put it in the correct place and move on to the next thing that doesn't work?
0 Me gusta
Mensaje 14 de 23
manjuo
I didn't upload two of the same pictures, but the program files folder was ABOVE your reply to go there. I took the 86 one so you didn't aske me for that too.
Or was that one C:\Program Files\Autodesk
Not correct?
0 Me gusta
Mensaje 15 de 23
manjuo
I agree, either you read or skim. So, I'm not really sure how this is the wrong folder path: C:\Program Files\Autodesk, but I've added another picture of the same thing JIC
How is this incorrect?
0 Me gusta
Mensaje 16 de 23
ChicagoLooper
Go to post #7 and perform step 1. Take a screenshot of the SUPPORT folder and upload it. Do not proceed to step 2.
Chicagolooper
0 Me gusta
Mensaje 17 de 23
manjuo
Go to post 6 and see the pictures. There are 3. The second is the support folder.
0 Me gusta
Mensaje 18 de 23
manjuo
As an update, the Factory Design Utilities cuix is not there either. Here is the support folder:
0 Me gusta
Mensaje 19 de 23
RobDraw
Have you considered going nuclear?
Rob
0 Me gusta
Mensaje 20 de 23
manjuo
I’m already maxed out on the crazy, if that’s what you’re referencing. Otherwise, I don’t know what you mean.
0 Me gusta
