Can't delete lines
Can't delete lines
I'm a complete beginner to AutoCad, so please forgive me!
I'd like to clean up a floor plan, so I can dimension it ready for construction. The plan has a lot of other lines for driveway, fencing etc all of which are not required. I've spent hours googling, and attempting different ways, but I cannot select these lines!
Replies (10)
rendermaster
checked your layers and be sure that layer you want to delete is not locked
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
If you can see them but not select them, you might want to check if they are on locked layers, or are coming from a reference file.
To select the lines what method are you using? Pick, crossing window, non-crossing window etc.
Hope this helps
All layers are unlocked, and all layers are unfrozen.
Argh, they could be coming from a reference file, which I don't have. How can I check if this is the case?
I've tried all methods - pick, crossing window and non crossing window.
carl.coghill
Are you able to upload the file so that we can have a look?
Carl Coghill
Senior Designer
AutoCAD 2018
Windows 7 Professional 64bit
LinkedIn
Appreciate the fast responses, thanks guys!
Vinayv4v
Seeing your white window, make sure you are not in layout tab.
Please upload a sample of your drawing.
Thanks & Best Regards
Cheers,
Vinay Vijayakumaran
Anthony_Latoche
 SALUDOS: @Anonymous
BUENOS DÍAS ACABO DE VER TU DUDA Y ESPERO TE SIRVA LA SOLUCIÓN:
TE RECOMIENDO QUE EL DIBUJO LO EXPLOTES COMANDO EXPLODE Y POSTERIORMENTE LE DES EN SELECCIONAR SIMILAR, POR OTRO LADO TRATAR DE UBICAR LAS CAPAS Y BORRAR DE MANERA CONTINUA.
SI LOGRÉ RESOLVER TU DUDA PUES PUEDES APOYARME CON 1 KUDO Y PONGAS ESTA AYUDA COMO SOLUCIÓN.
QUE TENGAS BUEN DÍA SALUDOS
TOPOCivilPeru SAC.
TOPOCIVIL PERÚ - Capacitaciones y Servicios para Ingeniería
Anthony Bagner Latoche Rosario - Gerente
https://www.linkedin.com/in/topocivilper%C3%BA/ / https://www.youtube.com/channel/UCJGPl0XrNzVSjcAdn4bzaDg / https://www.facebook.com/TopocivilPeru / https://topocivilperu.com/
RvW000
Suggest that you check  that you do not have any block in your drawing which may have a construction line embedded in it. Especially if you have a 'smart' block which has visibility states. Double click the block and cycle throught he visibility states. You may find the culprit hiding in the block.
slee005
Community Visitor
Community Visitor
thanks
