Hi guys please suggest how can we scale rotate the data using four reference point?
Hi and Welcome to AutoCAD Forum,
Would you please show us your CAD case, You may get more than answer.
This may help - see the second video in this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Hi @ssharma_panindia,
Welcome to the Autodesk Forums.
More details please. Screen shots or even post your drawing.
Dave
Dave Stoll
Las Vegas, Nevada
4 in a 3(D) world!?
Do you mean 2 ppints? 2 source and two target point = 4 ?
Use command ALIGN and skip the 3rd point
Sebastian
Sounds like you are looking for a least squares type fit where you have a set of control points and a set of reference points to be "fitted" into the control points. Many years ago I was in the land surveying business and I wrote such a routine, but it was just for points, not entities like LINEs, PLINEs, etc. Do you have 4 control points and 4 reference points? How far different are the control and reference points? Do you want to adjust more than AutoCAD POINTs?
