AutoCAD Forum
Can some explain survey units too me?
6 REPLIES 6
nrm0504
398 Views, 6 Replies
nrm0504
Hey guy I'm having trouble at work. I was given a DXF file from a surveyer that has points that are supposed to coralate piers. I have to overlay this data on our own architectural drawings and see if they line up ok. So when I open the DXF file it set to decimal and inches in the drawing units. The points measure out at 8 in but in reality they are feet cause server units or whatever.
My question is how do I go about scaling? Do I scale the survey points to 8 architectural feet or scale the architectural drawings down to match the points?
Any help would be appreciated.
Tags (1)
6 REPLIES 6
Patchy
in reply to: nrm0504
Patchy
If you live in the USA
Scale the survey drawing up 12 times because you use inch base, the survey uses feet.
nrm0504
in reply to: Patchy
nrm0504
So open DXF file, scale command, select all points, 12 enter. Keeping the drawing units at decimal inches?
Patchy
Patchy
The surveyor uses decimal of a foot, never with inch.
DXF in his drawing into an empty drawing with UNITS set for DECIMAL.
Then scale, all, 12 times.
Use CTRL + C (for copy) and select all.
Open your Architectural drawing and paste.
They should match.
They should match.
Pointdump
Pointdump
Hi Nikolas,
Can you post both of your drawings?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Hi Nikolas,
Dave
Dave Stoll
Las Vegas, Nevada
dbroad
dbroad
The surveyor must've incorrectly set the units for the drawing.  To fix, do either of 2 things:
  1. use -dwgunits to change from inch units to feet units but you probably shouldn't choose scale.  Answer no to the question about scaling model space and yes to scaling drawings on insertion.
  2. Scale the drawing received by a factor of 12.
Posting a small part of the drawing would help confirm the drawing setup.
Architect, Registered NC, VA, SC, & GA.
pendean
pendean
Community Legend
Community Legend
@nrm0504 Why not reach out to the surveyor that provided the DXF file and you both talk to each other about intent vs dxf content vs reality to solve it? I'd bet you both would be done with the topic and both well satisfied to boot 😉
AutoCAD Inside the Factory
