Hi!!
In my AutoCad the calculator doesn't shows the number pad.
What can I do to show it again??
Caetano
Solved by paullimapa. Go to Solution.
Could be a bug. Did you install latest updates? What AutoCAD version? Try disabling hardware acceleration or Gfxdx12?
Check out discussion here:
https://forums.autodesk.com/t5/autocad-lt-forum/calculator-disappeared/m-p/7002513#M151718
@Luancat
Hi, did the response offered above solve this issue for you?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
