I'm in Block Editor, and I clicked on the calculator icon to the right of the Distance Multiplier in order to input a variable and the calculator and all the subheadings have disappeared and it looks like this:
Where'd it go? And how do I get it back?
Thanks in advance!
Solved by greevedogg. Go to Solution.
@pendeanSorry, about that...
AutoCAD version is O.49.0.0 AutoCAD LT 2018
OS is Windows 10 64-bit
I found the solution. It's a bug. When I click on the calculator icon on the right side of a field in the properties menu to do a property calculation, QuickCalc popup window shows up but it looks like this:
The Number Pad, Scientific, Units Conversion, and Variables Sub-menus have disappeared...
Well, they haven't really vanished, like i thought. They're still there, just hiding under a hidden button. There should be a down-arrow button to the far right of where it says Property Calculation that expands the sub-menus:
The button is there to expand and collapse the sub-menus, it's just not visible, but if you hover your mouse over the area, it turns a darker gray. That's the only way that I stumbled across it. Likewise, if the submenus are visible, if you hover your mouse over the same area, there is a hidden collapse button there. I must have inadvertently clicked it and made the submenus disappear...
I will mark this as SOLVED, and now report this bug to the proper authorities...
No bug, must be your video card choking:
Turn off (or on) hardware acceleration in GRAPHICSCONFIG command and see if that helps. Also check your PC manufacturer website for updated drivers.
@pendeanIf I open QuickCalc, the down(or up) arrows for the collapse and expand submenus are present and visible:
They are not visible if I open the QuickCalc pop-up from the Property Calculation. Try opening the QuickCalc from here, and tell me if your down arrow is visible:
My graphics card drivers are up-to-date, and I tried both hardware acceleration on and off, still same result: No visible icon.
This has been passed on / reported
It's also a problem in AutoCAD too ...not just AutoCAD LT
Mike
