AutoCAD Forum
Calculate Extrusion height
5 REPLIES 5
CSM_MAI
744 Views, 5 Replies
I have a number of extruded circles in a model. I have to calculate the toltal length of these entities, but I can seem to figure out an efficient way of doing this. I found the lisp posted below, and it works fine for a single object. Is there a way to select multiple entities with lisp and calculate the extrusion height? Thanks for any info on this.
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/extrusion-height-of-a-3d-solid-in-aut...
5 REPLIES 5
hmsilva
in reply to: CSM_MAI
Untested
(vl-load-com)
(defun c:demo (/ i l tl ss)
  (if (setq ss (ssget '((0 . "3DSOLID"))))
    (repeat (setq i (sslength ss))
      (setq l  (getpropertyvalue (ssname ss (setq i (1- i))) "Height")
            tl (if tl
                 (+ tl l)
                 l
  (princ tl)
  (princ)
Hope this helps,
Henrique
CSM_MAI
in reply to: hmsilva
That works great. Is there a setting that I can add to it to have the measurements read out in engineering units instead of decimal?
hmsilva
I' a metric guy,
try
(vl-load-com)
            tl (if tl
                 (+ tl l)
                 l
  (if tl
    (princ (strcat "\nTotal Heigth = " (rtos tl 3 2)))
  (princ)
Hope this helps,
Henrique
CSM_MAI
Perfect. Thanks again for the quick response. I appreciate it.
hmsilva
You're welcome, CSM_WP
Glad I could help
Henrique
Forma Design Contest
AutoCAD Beta
