AutoCAD Forum
[CAD 2025] BUG Shift Fillet in Block
2 REPLIES 2
nguyennhattanpt
184 Views, 2 Replies
I have discovered bug in autocad 2025.
when editing blocks. Use the fillet command and hold down the shift key.
The algorithm appears in an endless loop.
Labels (1)
2 REPLIES 2
cadffm
in reply to: nguyennhattanpt
I greet someone who has activated the Next object snap as a continuous object snap.
This is not a general 2025 bug (or not that simple "shift-fillet in Block") , at least the problem does not exist in my example block on my PC in my 2025.0.1 version.
It also works without problems in the current product version 2025.1.0.
But I have not tried it with your Osnap settings, your PC or your block because I was unable to do so.
You see all the errors in the log
Try this:
RESET TO DEFAULT (and use the offer to export settings, safe this file)
Still a problem?
Re-Install ACAD
Still a problem?
Sebastian
RobRocks
More likely a glitch in the mouse or graphics driver than a bug in AutoCAD, unless you can repeat it on a different system.
What happens when you hover on the line using more of the pickbox?
Forma Design Contest
AutoCAD Beta
