Can't change text color
tmccar
Advisor Advisor
Message 1 of 8
tmccar
I have a lot of blue text notes on a drawing which I would like to change to black, but they stay the same even though I have changed color to black. Is the color governed by some other setting?
Replies (7)
Message 2 of 8
imadHabash
Can we have a CAD dwg sample please ?
Imad Habash
Message 3 of 8
tramber
They are not TEXTs but MTEXTs... for sure
Explode them 😉
Message 4 of 8
RobRocks
Are you changing the layer color, object color or overriding the text to change the color?
Message 5 of 8
tmccar
No problem
Message 6 of 8
tmccar
Yes I changed everything.
I suspect it's formatted that way
Message 7 of 8
cadffm
yes, you used internal mtext formats to change the color, instead to change the color of mtext objects.
www Search for StripMtext
and edit your mtext while in bedit.
Sebastian
Message 8 of 8
Kent1Cooper
They're all [nested in a big Block] Mtext with the color as internal color formatting.  You probably need to get into the Mtext editor on each one, select all the content, and change the color setting, or clear all formatting if there aren't other properties in the internal formatting that you want preserved [italics, font, etc.].
There's a routine you can search for called STRIPMTEXT that will do that for you in all of them together [when you are in REFEDIT/BEDITing the Block if you need it not to be Exploded].
Kent Cooper, AIA
