AutoCAD Forum
Message starting Autocad
2 REPLIES 2
r_arechavaleta
228 Views, 2 Replies
Hello. I´m using a 30 days trial version. I want to automate an action, but to do it I need that Autocad starts directly and now appears a message that I´m using a trial version, that stops my routine. What could I do to cancel that message? With this I coulndt test the product and I dont know if it could be useful to me. THANKS
2 REPLIES 2
cadffm
in reply to: r_arechavaleta
now, click ok
you know that your automations works until this message and it opens the file.
If it stops now:
Create a test routine for the rest of your automation.
If it works, it works.
Nasty and not 100% sure it will be the same as without this box.
You can set up a "pop up blocker". A windows tool which you can set up to press key/buttons, depending the windows title.
Sebastian
pendean
You cannot deactivate that prompt.
Your "automation" needs to be re-written to use an open session of the trial version instead without restarting the trial version.
Show your code if you want help with that.
AutoCAD Inside the Factory
