Is there any way to retain clipped boundaries when bursting? Every time I burst blocks with clipped box, everything outside the boundaries would appear. Thanks!
Solved by 3wood. Go to Solution.
Hi @Anonymous,
I don't use this command very often so I don't have a ready answer. If you can share on of your files however, I am happy to investigate this for you.
You can try EXPLODEALL (need a free registration) which can explode blocks and trim off its subentities out of the clip boundary.
Hi John,
I should rephrase my question to how to burst block without revealing what's outside the clip boundary. I've attached a file as an example. Thanks!
Hi @Anonymous,
Thanks for the file. I have a better idea of what you are looking for when bursting the Xclip. I have not found a native way to do this yet but do see there is an app in the Autodesk App Store that is designed to do this.
Hi @Anonymous,
i am curious to see if you tried the app I linked to in the App Store. I am hoping that worked for you.
Hi John,
It looks like that's what we need in our office, I'll need permission to purchase the app thou. MANY THANKS!
