Bin file open
Bin file open
Bin file open
I download my auto cad drawings to my android from my e-mail. But I hadn't installed auto cad app. So that files show as bin (.bin) files. There are installed auto cad on my pc. So I tried to open that bin files with so many bin files opening softwares. But that format doesn't support for those softwares. ( already I have deleted the e-mail also ) Please somebody suppose me some solution.
rkmcswain
Did you try changing the file extension to .DWG, for opening on your PC?
R.K. McSwain     | CADpanacea | on twitter
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Are you having problems opening on Android? Here is a link to the DWG viewer on Google Play.  If you are trying to find a viewer for your PC here is a link for some additional options.
I am not sure why the files show up as BIN extensions. Typically files will show up in DWG or DWF file extension types.
John Vellek
Hi, thanks you very much for the solution. It simply was solved by just changing extention to .dwg on Pc.
