AutoCAD Forum
burst block but retain clip boundaries
6 REPLIES 6
3522 Views, 6 Replies
Is there any way to retain clipped boundaries when bursting? Every time I burst blocks with clipped box, everything outside the boundaries would appear. Thanks!
6 REPLIES 6
john.vellek
Hi @Anonymous,
I don't use this command very often so I don't have a ready answer.  If you can share on of your files however, I am happy to investigate this for you.
John Vellek
3wood
You can try EXPLODEALL (need a free registration) which can explode blocks and trim off its subentities out of the clip boundary.
in reply to: john.vellek
Hi John,
I should rephrase my question to how to burst block without revealing what's outside the clip boundary. I've attached a file as an example. Thanks!
john.vellek
Hi @Anonymous,
Thanks for the file. I have a better idea of what you are looking for when bursting the Xclip.  I have not found  a native way to do this yet but do see there is an app in the Autodesk App Store that is designed to do this.
John Vellek
john.vellek
Hi @Anonymous,
i am curious to see if you tried the app I linked to in the App Store. I am hoping that worked for you.
John Vellek
Hi John,
It looks like that's what we need in our office, I'll need permission to purchase the app thou. MANY THANKS!
AutoCAD Inside the Factory
