Burst a block without explode the graphic part
luigiverdenico
Message 1 of 9
luigiverdenico
Hi all,
if I have a block with attributes, is it possible with command burst (or other commands) convert attributes in texts and, at same time, not explode the graphic part of the block?
Luigi
Replies (8)
Message 2 of 9
jayhar
Hi
1, Two Lips Upload to convert attributes in texts Find the attachment.
2, Block with attributes does not work in this Lips, Only BURST can use (if Allow Exploding is Yes)
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 3 of 9
luigiverdenico
@jayhar wrote:
Hi
if these lisps don't work with block with attributes (as you wrote), why you posted them?
Message 4 of 9
Alfred.NESWADBA
>> part of the block?
there is no standard command available which can do that. You might run BURST in a copy of that file to get the texts created from attribute values and copy/paste the text objects back to the original dwg-file (and clean the attribute values there).
BUT ... may I ask what for that is done, that only destroys a structure and I can't see the profit in doing that.
Understanding the background of that need might bring up some alternatives 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 9
luigiverdenico
>> part of the block?
- alfred -
Hi Alfred,
in my drawing, I have to copy inputs from other designers. One of them uses block with more attributes for the definition of the code of items (example YYY/XXX). The problem is that: if i want move the code of one of this item (because, for example, it overlaps other items) i have to move 3 attributes separately (first is "YYY", second is "/", third is "XXX") with loss of time and accuracy. For that reason, I apply command burst on block and then I join the 3 texts for obtain one only to move as I want, but meanwhile the blocks are exploded, weighting the file .
Message 6 of 9
jayhar
Read Carefully and replay. i already post "Block with attributes does not work in this Lips"
only convert attributes in texts
Message 7 of 9
Alfred.NESWADBA
can you please upload a drawing that has some of the source block items + on a different layer a text with the visibility you need to create from the blocks?
Just a feeling: the formula XXX/YYY can be simply done by a field, nothing needed to be exploding/bursting/... (maybe).
- alfred -
Alfred NESWADBA
Message 8 of 9
RobDraw
The OPs issue is with blocks containing attributes. Your LISP routines are useless for the OP, if they don't work with attributes.
Edited by
Discussion_Admin
Rob
Message 9 of 9
@jayhar hi,
Why are you referring to LISPS in this instance?  Its a block in its entirity...so block editor opens the block.  @luigiverdenicoIf you can find out if there are nested blocks it would be beneficial, but i think in this instance it may be that the text and graphics are united into one big block, so BURSTING them burst everything.  I would create a copy of the block first and then burst one and move the text over from the bursted and get rid of the graphics bursted so they dont weigh the file.
