AutoCAD Forum
broblem with mtext
6 REPLIES 6
611 Views, 6 Replies
broblem with mtext
i try to draw mtext and that what i got
and: MTEXT
Current text style:  "Standard"  Text height:  0.2000  Annotative:  No
Specify first corner: _non
Specify opposite corner or [Height/Justify/Line spacing/Rotation/Style/Width/Columns]:
Cannot find shell program
6 REPLIES 6
BrettWright
Hi Amal,
Which Autodesk product are you using where you're having trouble with mText?
Let me know and we'll get you directed to the right location.
Brett Wright
in reply to: BrettWright
Hi
I use AutoCAD 2014, I start having this problem when I tried to set a new text style to use before that it was okay.
AMAL AMIR
CADD OPERATOR
SKANSKA-JAY DEE JV/ FIRST STREET TUNNEL
2507 FIRST ST NW, WASHINGTON, DC 20001
TEL: 202-450-3006 -EXT. 28
This message, including any attachments hereto, may contain privileged or
confidential information and is sent solely for the attention and use of the
intended addressee(s). If you are not an intended addressee, you may neither
use this message nor copy or deliver it to anyone. In such case, you should
immediately destroy this message and kindly notify the sender by reply email.
Thank you.
doni49
@Anonymous wrote:
Hi
AMAL AMIR
CADD OPERATOR
Thank you.
I was able to reproduce this issue in 2014 by setting the variable MTEXTED to LISPED.
Reset it to INTERNAL and it should work.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
HI,
  DID YOU FIND OUT WHAT IS WRONG WITH THE MTEXT OR HOW CAN I FIX IT.
THANKS
AMAL AMIR
BrettWright
Amal, my apologies in the delay, for some reason I didn't see your response come back through our system.
either way, what i've done is move this question over to the AutoCAD 2014 product forum so that team can engage with you on this specific issue,
again, my apologies in our delayed response back to you.
Brett Wright
The only real problem when discovering new tricks is that you can actually go through years before you reach a real gem that can have a big impact on how things are done. 202-450 Dumps
This is why I offer as many useful tricks as possible on a particular topic to make things easier for future reference. In this article, I will share a series of tips and tricks to create MText objects. If I run just one trick of this article, I will do my job.
Multi-line text objects were introduced in AutoCAD version 13 (1994) and had some basic features such as word formatting and "By-Entity" formatting. Since then, he has become an intuitive and intelligent editor in his place. The purpose of this article is to override the basics.
AutoCAD Inside the Factory
