I'm working with AutoCAD to create my electrical schematics according to IEC standards. I drew the symbols and I saved them as blocks (fig. N1) but the problem is that I can't find them in every new drawing I start working on, I always need to import them from the previous ones.
Is there a solution to make them as default blocks in every drawing?
When working with those blocks the insertion of the first one is simple however the insertion of another block with the right mouse button requires scale and rotation angle(fig. N2).
Can those parameters be default parameters?
Thanks in advance.
Solved by ara_neresesian. Go to Solution.
One option @Anonymous is to create a .DWT file.
Júnior Nogueira.
Por favor, Aceitar como Solução se meu post te ajudar.
Please Accept as Solution if my post helps you.
HI
build your own ToolPalettes and put all blocks inside ToolPalette save your drawings .
that is what you want.
keep block files in a safe place
good luck
